ernstt
2012-10-11T13:50:09Z
I'm working vb6 with igrid version 4.70 build 0153
I can't get an image during a drag drop action, even when I set the dragicon value with a valid icon, it does
show an image during the drag action
Any ideas ?
2012-10-12T06:05:01Z
ernstt,
It's not possible to say what is wrong from this tiny description. Prepare a short demo project we can launch to see the problem, and send it to our support address please.
You can also look at the series of the Drag-b-drop samples in our online iGrid ActiveX Extra Sample library:
http://www.10tec.com/Products/ActiveX/iGrid/Extra_Samples.aspx
They will give you some ready-to-use solutions you can examine. Perhaps, they will help you to understand what is wrong.
ernstt
2012-10-12T12:56:13Z
ok, sorry, I will ask it in a different way :
is it possible to have an image visible during the drag action instead of a square in your example from your website : Drag-n-drop inside grid (enhanced) ?
2012-10-13T07:02:23Z
In the sample 'Drag-n-drop one row between 2 grids' we demonstrate how to have a custom image for the drag operation.
Does it work in your case?
ernstt
2012-10-18T12:34:48Z
Strange, I have download from the example site the zip file DragNDrop2Grids.zip,
it only demonstrates the functionality without image... any idea ?
or do I have the wrong zip file ?
2012-10-19T14:53:58Z
I have just checked it in my Win7 Home Premium (x64 SP1). All works as on the sample screenshots.
