Mr. DX
2011-05-16T14:59:23Z
Does drag-and-drop inside iGrid or between two grids work with MS Access too? If yes, does somebody have a few lines of code which work? Thanks alot!
iGrid-version: 4.6
MS Access version: 97
Mr. DX
2011-05-17T21:08:45Z
I solved the problem myself. As usual in Access you need to use the Timer-event of the form because Access doesn't process other events while processing an event 😞
