Hi, Igor,
when dragging and dropping columns the behaviour of ColHeaderEndDrag is unclear.
I built a small sample database to demonstrate the behaviour.
Just drag and drop columns around. Sometimes the values are correct, but definetely not always.
Especially: what should I expect when dragging to the end?
The values are the same as if dragging before the last column.
Btw. going to design view after testing this brings a endlessly repeated
"shutdown" Runtime-Error 91 until the application closes.
Tested with .1058.
Thanks for any help - Mark
iGridTestColDragEnd.zip
(26kb) downloaded 194 time(s).
