ThatRickGuy
2012-11-19T20:35:56Z
Hey Folks,
Anyone know if there is a way to get the design view in VS2012 to work with iGrid 2.5?
http://www.10tec.com/For...harpDevelop-4-0-IDE.aspx  but I'm not having much luck.
Thanks,
-Rick
ThatRickGuy
2012-11-19T23:44:54Z
If there isn't a way to get the 2.5 version to display in VS2012, the only things I saw change on trying the 4.0 version were the Cell.Row.Font and iGSortType.ByCustomer were no longer available. Are there other properties/constants that took the place of these?
Thanks,
-Rick
2012-11-20T06:50:25Z
Rick:
引用:
There are two sides of the problem. The first of them is the registry keys which helps VS to find the design-time support DLL. The second one is the general ability to use a control for .NET Framework client profile development. iGrid.NET 2.5 and earlier versions can be used only with the full profiles of .NET Framework, but the latest versions of VS (2010, 2012) create projects with the default client profile setting.
Looking at your description, you need to use the full .NET Framework profile with iGrid 2.5, but we highly recommend to upgrade to the latest version (4.0) as it is designed specially for client profiles end users expect to see. And moreover, the v2.5 is no longer supported, and new features and bug fixes will be implemented only in the latest versions.
2012-11-20T06:53:39Z
引用:
Read the comprehensive What's New document supplied with the control to find the answers to questions like this. Here are the corresponding excerpts:
7. [New][Change][Improved] In previous versions, you accessed the cell style properties defined for a particular row through a set of properties in the iGRow class – such as CellType, BackColor, CellSelectable, Font, etc. There were no strong naming system used for those properties because of step-by-step development of iGrid in different versions, so it was hard to say whether a property of the iGRow class is related to its cells or defines the look or behavior of the whole row (for instance, like the Type property).
In this version all cell properties nested directly into the iGRow class were removed, and now they should be accessed only through the CellStyle object property. Thus previous calls like
iGrid1.Rows[5].TextAlign = iGContentAlignment.BottomRight;
should be transformed into the following one:
iGrid1.Rows[5].CellStyle.TextAlign = iGContentAlignment.BottomRight;
To minimize memory consumption and time of rows creation, these CellStyle objects (instances of the iGCellStyle class) are null references by default, but they are created on the fly when you access them. This is done for the convenience of coding - to avoid manual creation of iGCellStyle objects in code each time when you change a cell property in a row. This works similar to the iGrid cells, when the cell style object associated with a cell is created automatically when you change a property of the cell.
There is only one drawback in this approach: in this scenario you cannot test whether a row’s CellStyle object is a null reference (i.e. it was not assigned). To allow this, iGrid has the new Boolean CreateRowCellStyleDynamically property which determines whether a row’s CellStyle is created automatically if needed. By default it’s True, and this corresponds to the behavior described above. To prohibit automatic creation of the CellStyle objects in the iGRow instances, set this property to False.
12. [Renaming] The items of the iGSortType enumeration were reordered to have a more logical order when similar items are grouped next to each other. The iGSortType.ByCustomer item was renamed to a more proper name iGSortType.Custom.
ThatRickGuy
2012-11-20T23:01:16Z
Awesome!
Thanks,
-Rick
