This is a real showstopper. So i hope there is an easy fix.
I use win10, access 2016, iGrid 6.5
I use addcol to add headers and FillFromRS to fill the grid.
Even with large recordsets it all works fast.
However scrolling down using the mousewheel is a problem.
1.Scrolling stops after the second(?) page.
2.The scrollbar indicates that there should be movement.
3.Clicking on another control refreshes the grid and scrolling works again.
4.See 1.
What can i do to solve this problem?
The application will be rolled out using Access 2010. Will this pose a problem?
Thanks!
Guus
