I've been using the ActiveX version of this control on an excel form for a while now and it's been great. All of a sudden it does not load when I launch the form. In VBA, the control is not visible, unless I click in the area where it is supposed to be and in that case, I can see the outline of the control (selected control border). I can also see all of the properties, but when focus shifts to something else, it is like the control was never there.
I have checked the references to ensure the 10Tec iGrid Control 6.5 is still there and checked (not Missing). I have even unchecked it and remapped the reference to the .ocx file, but it didn't help.
I can create a new form, select the iGrid control from the toolbox and draw it out on the form, but again, I just get a "got focus" outline on what otherwise looks like a blank form.
I've also restarted the PC, but nothing is helping. Any ideas?
Edited by moderator
2018-07-12T06:53:31Z
Reason: Igor/10Tec: changed the post status from 'issue' to 'none' as the problem is not on the 10Tec side
