paolo
  • paolo
2016-11-29T09:49:04Z
hello, I am trying using iGrid.NET 5.0 for .NET 4.0 - 4.6, Trial Version
and then of course buy license
It happens to me one thing, when I doubleclick and unleashed the GridRicerca.DoubleClick event, do the special work of the sql tables and then I would like to automatically close the form where the grid (iGrid), but strangely I will fault
the stak is the following:
  TenTec.Windows.iGridLib.iGrid.IsPointOverRowLevelArea
TenTec.Windows.iGridLib.iGrid.ProcessEmptyAreaMouseUp
source:
TenTec.Windows.iGridLib.iGrid.v5.0
message:
Object reference not set to an instance of an object.
I know give me a help
thanks paul
2016-11-30T07:44:43Z
Paolo, we would be glad to help you, but we need a sample that demonstrates the problem. Can you prepare and send us one?
paolo
  • paolo
2016-11-30T10:51:56Z
hello thanks for the quick reply
I prepared the project as I can send?
thanks paul
2016-12-01T07:16:37Z
You can find the effective email support address at any time on our Contacts  page.
An alternative option is to upload your files to this forum.
Before packing your project to a zip archive, please, remove the Bin and Obj subfolders from the solution folder.
