mcs
  • mcs
2018-12-03T08:31:21Z
Hello together,
i have a question:
my iGrid is setup like this:
selection mode: multiextended
RowSelectionInCellMode: multiple rows
RowHeaders: visible = true
When i now select some rows (f.e. with STRG + click) and then right click on any row header row the selection is gone.
But if i right click in any cell the selection of the rows stays.
what i want is that only left mouse click can change row selection and right click does noet.
Background is that i want to open a mouse context menu with right click and therefor the row selection should not change.
How do i have to setup my iGrid or do i have to handle an event?
best regards
2018-12-04T08:20:14Z
This can be easily implemented with the
private void iGrid1_RowHdrMouseUp(object sender, iGRowHdrMouseUpEventArgs e)
   if (e.Button == MouseButtons.Right)
      e.DoDefault = false;
      // Display your context menu
BTW, do you think the selection must be changed only when the left mouse button is clicked - at least, by default? We could change this behavior in the future updates of iGrid.
mcs
  • mcs
2018-12-04T10:33:26Z
Hey Igor,
thanks for the quick feedback.
for me default should be to select rows with left mouse click only, yes
