Rob Down Under
2014-08-26T10:41:40Z
I am new to the iGrid, and am evaluating it (I have used the SGrid2 for many years)
One of the desirable features is the printing and Excel automation, which are present/explained in version 3 samples.
I have raised another post specifically on that (no version 5 examples)
THIS POST is NOT specifically on that. Instead it asks -
"Are there any documents to assist programmers to translate between the version changes ?"
I am bravely attempting to upgrade that print sample, but it is tortuous.
EG .Redraw ain't called that anymore
Also the Col, cell, etc, alignment properties/parameters/arguments have been changed between the versions.
Has anyone prepared a 'Rosetta Stone' table or guide, to assist anyone trying to convert say version 3 programs into version 5 programs
Thanks,
Rob
2014-08-27T14:54:04Z
We have the comprehensive What's New documents for every release of iGrid - use them.
They can be always found online here:
http://10tec.com/activex-grid/whats-new.aspx
Rob Down Under
2014-08-28T04:42:37Z
Thanks Igor,
I have downloaded all of the 'change' documents (and the updated samples)
Regards,
Rob
