最想要igrid.net有一个表格弹出表格的功能,我点标识2的按钮弹出表格,选择数据后可以按箭头的方向返回数据到父表格
I want igrid. net to have a form pop-up table function. I click the button identifying 2 to pop-up the table. After selecting the data, I can return the data to the parent table in the direction of the arrow.
Click to View Image228 View(s)
Click to View Image214 View(s)
然后如果有旧值,重新弹出表格 也是要可以定位到 旧值的那一行
Then, if there is an old value, the pop-up table should also be able to locate the row of the old value.
然后弹出的表格这部分想要改成这个样子
Then the pop-up form part wants to change to this way.
Click to View Image216 View(s)
过滤这一块很想要这个效果,这个是devexpress 的
The filter piece wants this effect very much. This one is devexpress's.
Click to View Image222 View(s)
表格列 弹出表格选择数据后返回填充 想要这种效果,
The table column pops up the table to select the data and then returns to fill in the desired effect.
Click to View Image218 View(s)
MultiColDropDown_iGrid_6.0_CS.zip
(45kb) downloaded 208 time(s).
Edited by user
2019-03-06T05:15:04Z
Reason: Not specified
