ahpiau18
2014-01-14T23:31:31Z
Hello 10Tec,
i found an issue on header and cell is not align.
any function/setting can reset the header and cell alignment?
thanks
mis-aligned
2014-01-15T07:48:45Z
Are you using the latest version of the control (5.0.86)? As I remember, we had this problem some years ago, but it has been already fixed.
If it still occurs in the v5.0.86, send us a project we can launch to reproduce the bug, please.
As for a method one can use to align column headers and columns, there is no such a method as this problem should never occur, so we will be glad to fix this bug ASAP if it is still present in iGrid.
