frdata
2014-02-03T02:33:07Z
I am using iGrid to replace the regular ComboBox because iGrid has the convenient CellValue property.
However, iGrid would only trigger the drop down action if clicked on the arrow button.
It would not trigger the drop down if clicked elsewhere, as opposed to the regular ComboBox which triggers the drop down action if clicked anywhere on it.
It is possible to have the same functionality in iGrid.
Thank you
2014-02-03T08:37:36Z
One of the standard commands to start editing in iGrid is a double-click - for a combo box cell it also opens the drop-down list
If you need to do that on single click, you can process such event as MouseDown or MouseUp and issue the RequestEditCurCell method from it. For combo box cells, this method opens the drop-down list.
frdata
2014-02-03T09:54:54Z
Fantastic. What an amazing control.
Thank you
