arty
  • arty
2019-10-08T10:33:09Z
cell input Vietnamese display gibberish characters
but input Chinese display normal
OS:Win7 or Win10
2019-10-08T13:51:38Z
Does the used font support Vietnamese characters? Check also the Charset property of the Font object.
arty
  • arty
2019-10-09T01:44:48Z
exsample:input h+o+c+j -> học,but iGrid display as follow,it is not correct,
Input Vietnamese characters on cell of iGrid
How Check the Charset property of the Font object ? as follow?
Font chaeset property
arty
  • arty
2019-10-09T04:49:18Z
UserPostedImage
https://10tec.com/FS/Pro...New_in_Latest_Builds.txt  write as follow:
iGrid does not still allow you to edit Unicode text from codepages which differ from the main locale code page selected in Control panel, but such languages as Chinese is supported in editing mode too.
Does 10Tec_iGrid_ActiveX_7.x support Vietnamese languages like Chinese in editing mode?
2019-10-09T07:08:59Z
When you click the ellipsis button in the property cell value for the Font property, the Windows font dialog appears and you can find the Charset setting in it. An alternative way is to set the Charset property in code.
However, all this may make sense only if you are using an outdated version of iGrid like the v2.51. The latest versions of iGrid implement a new cell editor based on the Unicode edit control and your problem may go away simply by switching to the latest version. Try it.
arty
  • arty
2019-10-09T10:23:14Z
How to set he Charset property in code?
I try the latest version the problem still remain.
arty
  • arty
2019-10-10T01:17:08Z
in vb The latest versions of iGrid Active Control code:
Private Sub Form_Load()
iGrid1.Font.Charset = 163
on Grid control display English and Chenese and Vietnamese at the same time.
So set iGrid1.Font.Charset is not a good way.
2019-10-10T05:09:48Z
Have you tried iGrid 7.0 as I suggested? If the problem remains, send us a sample to reproduce the issue.
arty
  • arty
2019-10-12T01:44:20Z
you install Unikey first.
then run iGrid700_Demo.exe,on My Customers Form You try to input Vietnamese characters hocj to a cell, if display h?c it is not correct,display học is correct.
We are purchasing iGrid700 through middlemen. Please help us solve our problems as soon as possible.
2019-10-15T15:29:09Z
We do not use Vietnamese at all and we do not know how to enter these specific Vietnamese characters from our European keyboards.
However, I copied the text học from this forum into the My Customers grid without any problems. If this can be done, then I think Vietnamese characters can be also entered from the keyboard.
Can you copy/paste Vietnamese texts properly into iGrid?
arty
  • arty
2019-10-17T04:35:50Z
Yes,I can copy/paste Vietnamese texts properly into iGrid.
but ...
