Bruno Montalvan
2014-04-21T17:51:11Z
Good morning!!
What can I do to not clear the current cell, when I press the key delete, thanks.
2014-04-22T15:02:58Z
You can do that in the KeyDown event. Check whether the pressed key is DELETE (see the KeyCode event parameter) and set the bDoDefault parameter to False if so.
Bruno Montalvan
2014-04-22T15:09:40Z
It works!!!
Thank you very much ...again.
