lizano
2021-06-03T16:21:09Z
Greetings, my question is I am using Igrid activex Version 7.0 in vb 6.0 my question is how do I have the SetfocusRect in the grid, but at the same time keep the row selected.
in other words have the row selected but have a FocusRect highlighted, which I can navigate between columns and if I give enter the possibility of editing that highlighted cell.
Thank you
2021-06-04T15:03:18Z
To do this, first enable multi-selection mode by setting the MultiSelect property to True. After that you can move the current cell marked with focus rectangle without losing the selection if you hold down the CTRL key while pressing the arrow keys.
