enveetee
2014-10-30T11:13:06Z
How is it possible to select an entire row when you use right-mouse-button (left-mousebutton works fine)
2014-10-31T14:50:48Z
If row mode is on, the grid should select the entire row automatically even if you click its cell using the right mouse button.
Can you show us some code that demonstrates the issue?
