StephleHardi
2022-07-06T13:03:33Z
Just a small suggestion
I noticed that the text displayed when evoking RequestCellToolTipText, RequestColHdrToolTipText or RequestFooterCellToolTipText has a duration of about 5 seconds
Sometimes the written text may take more than 5 seconds to read. (Even if the goal is to make short messages)
It would be nice to be able to determine the exposure time. (e.duration = )
What do you think of that?
Stephane Chabeau
France
2022-07-06T14:58:29Z
iGrid creates a tooltip with the default values for time-related properties. I agree with you - it would be nice to change the display time in some situations. Do you think we need a new property in iGrid to control that parameter for all tooltips, or it would be better to specify custom display time for a particular tooltip? In the latter case, it could be a new parameter (say, DisplayTime) in the tooltip-related events you listed.
StephleHardi
2022-07-06T15:46:18Z
Personally, both solutions are suitable
so, choose the easiest to modify for you
Thank you very much for your listening
2022-07-08T07:24:24Z
An interesting dilemma :)
A property is a good declarative way to specify the display time - especially if you want the same delay time for all tooltips. But if you need to set a specific display time for particular tooltips (say, in one column containing cells with long texts), you will need to add an event handler for the corresponding Request*ToolTipText event and set the property value. Note that we will need to specify the default display time too for other 'normal' cells:
if (<specific cell>)
  iGrid.ToolTipDisplayTime = <specific time>;
else
  iGrid.ToolTipDisplayTime = <default time>;
If we use the approach with the event object property, we will do this the following way:
Another question is whether to have 3 separate properties for the 3 iGrid areas (cell area, footer cells, column headers). If we use approach with one iGrid property for all, then we will need to write 3 event handlers for all areas (RequestCellToolTipText, RequestColHdrToolTipText and RequestFooterCellToolTipText) because we will need to abandon the specific display time setting made for one of these areas.
What do you think?
And one note regarding this:
引用:
Even if we do not redefine the tooltip in one of these events, the default duration is still 5 seconds. Take this into account while thinking about the answer.
StephleHardi
2022-07-08T08:03:53Z
Igor, Thank you very much for your attention to suggestions
For my part, I would prefer a single display time for all tooltips because, anyway, the tooltip disappears when you leave the hovered area.
This would suffice for my own purposes but maybe other users would like a dislay time for each tooltip
Also, Igor, do what seems best to you because your choice will suit me perfectly
And thank you again for listening.
Stephane
2023-05-12T14:54:34Z
iGrid.NET 11.0 released today provides a way to implement what you suggested easily - with the AutoPopDelay property of those tooltip-related events. An example of how to set the cell tooltip display time to 10 seconds is below:
private void iGrid1_RequestCellToolTipText(
    object sender, iGRequestCellToolTipTextEventArgs e)
    e.AutoPopDelay = 10000;
