E.g. the following won't produce the desired behaviour of opening up an AutoFilter window :::
private void iGrid_KeyDown (object sender, KeyEventArgs e) {
switch (e.KeyCode) {
case Keys.F3:
igAutoFilterManager1.ColAutoFilter(1); // Well, not fit to purpose.
e.Handled = true;
break;
So what can I possibly do in order to get an AutoFilter window popping up from a keyboard action, without having to mouse-point-and-shoot a column header button ?
This question of mine is probably due to a serious lack of C# expertise, but please help ?
Or where should I look in documentation, or in Help, or in examples ?
Thanx in advance !
P.S. ::
https://10tec.com/winforms-grid/autofilter.aspx => states the following :::
9. A column's filter box itself can be opened from the grid using a key or key combination defined by the developer.
=> OK, but how ?
Edited by user
2022-07-08T13:21:44Z
Reason: Not specified
