vb-dev
2023-01-05T16:02:17Z
When a Cell's text is clipped, the ellipsis that indicates this appears in the middle of the text string. Is it possible to force the ellipsis to appear at the end of the string instead?
Thank you.
2023-01-06T07:52:48Z
Strange, the default setting is to display ellipsis in the end. Check the iGCell.TextTrimming property.
vb-dev
2023-01-06T19:06:11Z
Thank you, Igor. The schema in which I store all property values for an iGrid contained the incorrect default on the column associated with iGCell.TextTrimming; it is corrected and works as expected now.
