RaymondC
  • RaymondC
2024-06-17T14:51:54Z
I purchased iGrid v7.5 to use in a new 64-bit Access project. I also have an older 32-bit Access project that uses a previous version of iGrid and I plan to upgrade it to the latest version.
I have two questions.
#1 The single file iGrid750_10Tec.ocx is used for both 32-bit and 64-bit version of Access, correct?
#2 Since this new version supports 64-bit Access, do I still use Regsvr32.exe to register the new version of iGrid?
Thank you.
2024-06-17T15:05:14Z
#1: No, it is only for 32-bit apps.
#2: Yes, use the same regsvr32 utility to register the new OCXs.
RaymondC
  • RaymondC
2024-06-17T15:22:41Z
I purchased the wrong iGrid? How do I purchase the "modern" version that includes BOTH 32-bit and 64-bit versions?
Henrik
2024-06-18T09:48:01Z
I think there are two separate files.
The version holding both 32 and 64 bit is 7.5.0045. The latest retail version I've received is 7.5.0025.
/Henrik
RaymondC
  • RaymondC
2024-06-18T10:41:00Z
That is the version I purchased but it only included one file. I owned a previous version so naturally I chose the renewal purchase option which is a little less expensive.
Henrik
2024-06-18T10:43:53Z
Guessing that we'll just have to wait for Igor to shed some light on this matter
2024-06-18T14:08:14Z
The retail package for the latest version (7.5 build 45) contains 3 OCXs: the classic iGrid OCX in the Bin32 folder (iGrid750_10Tec.ocx) and the 2 modern iGrid OCXs in Bin32x64 (iGrid750_10Tec_win32.ocx
and iGrid750_10Tec_win64.ocx). You need the last 2 and you should find them in the retail zip package.
RaymondC
  • RaymondC
2024-06-18T14:34:35Z
The email I received on June 13th from MyCommerce contained a download link for: iGrid.7.50.0025.Retail.zip
It is an earlier build and only contained one OCX file in one BIN folder. There is no Bin32 or Bin32x64 folder.
Click to View Image75 View(s)
2024-06-19T07:22:56Z
Sorry, there was a problem with updating download links in the payment processor. It has been already fixed.
The download link to the retail builds of iGrid 7.5.45 was sent to your email stated in the license renewal order. Confirm that all is ok now, please.
Henrik
2024-06-19T07:32:50Z
Great!
Do I need to contact my reseller (moonsoft.fi) to get a new link or can we expect a new mail directly from you?
RaymondC
  • RaymondC
2024-06-19T12:58:16Z
Thank you, Igor. The new download link is working correctly.
Ray
2024-06-20T07:45:05Z
Henrik, the download links have been sent to your registration email too.
Henrik
2024-06-20T07:47:13Z
Thank you Igor. I got the mail!
