RaymondC
  • RaymondC
2016-03-16T16:01:27Z
I think I found another minor bug.
If a grid (v6.0.21) has AllowSorting set to False then the grid does not internally sort the rows before grouping them.
Please let me know if you need a sample to show the bug.
Ray
RaymondC
  • RaymondC
2016-03-16T16:25:48Z
In the attached sample, the grid has the AllowSorting property set to false. When you click the button to group by the CustomerID column, you will see that grouping does not work as expected. If you then change AllowSorting to True, the grouping will work correctly.
Thank you.
  iGrid Problem2.zip (95kb) downloaded 103 time(s).
2016-03-17T07:46:47Z
This is not a bug, this is a new feature of iGrid that appeared in the v6.0. If AllowSorting is False, you can group the grid without sorting it first, which can be useful in some scenario.
Read the pertinent topics in the help file:
Click to View Image105 View(s)
