Corrado
2011-03-31T16:32:50Z
Is it possible to have more than multiple columns in group row, and can they have number and widths different from columns in other levels?
Thank you
2011-04-01T06:54:28Z
iGrid does not have a built-in feature to define another, "nested" column structure for group rows, but this task can be easily implemented using custom drawing. You can also draw your won contents in group rows like you can do that in normal cells.
