David.CML
2016-05-06T12:22:27Z
This is the code I use to build and add data to an iGridControl and I am finding my applications memory usage is over 1GB whereas it is normally about 100mb
there are between 200 and 300 rows in the table and I have the filter manager setup
public partial class LoadsOut : Form
        public LoadsOut()
            InitializeComponent();
            comboBoxEx1.SelectedItem = comboBoxEx1.Items[0];
        private async Task UpdateTable(DateTime WorkingDate, string value, DateTime? ChangeTime)
            var MMtOnly = Global.UserAuthorisations.Any(a => a.AuthArea == "LoadsOut" & a.AuthLevel == 1);
            var TrucksToDisplay = new List<TsData.TruckLoad>();
            int windowStart = 10;
            int windowEnd = 34;
            if (value == "PTZ")
                windowStart = 10;
                windowEnd = 20;
            else if (value == "LLC")
                windowStart = 20;
                windowEnd = 34;
            while (TsData.IsUpdatescriptRunning)
                Application.DoEvents();
            TrucksToDisplay.AddRange(TsData.TruckLoads.Where(t=>MMtOnly? (t.HaulierName== "MMT"):true).Where(t=>(t.DepartBy.HasValue? (t.DepartBy.Value >= WorkingDate.AddHours(windowStart) & t.DepartBy <= WorkingDate.AddHours(windowEnd)):(t.InboundLoads.Any(l=>l.CollectionTime>= WorkingDate.AddHours(windowStart+12)& l.CollectionTime <= WorkingDate.AddHours(windowEnd + 12))))));
            int countV = TrucksToDisplay.Count;
            int i = 0;
            while (i < countV)
                var truck = TrucksToDisplay[i];
                if (truck.ChangeTime >= (ChangeTime.HasValue ? ChangeTime.Value : DateTime.MinValue))
                    MethodInvoker inv = delegate
                        iGRow row;
                        if (iGrid1.Rows.KeyExists(truck.TruckID.ToString()))
                            row = iGrid1.Rows[truck.TruckID.ToString()];
                        else
                            row = iGrid1.Rows.Add();
                        row.Tag = truck.ChangeTime;
                        row.Cells["Destinations"].Value = string.Join("/ ", TsData.OutboundLoads.Where(t => t.TruckID == truck.TruckID).GroupBy(l => l.Consignee).Select(l => l.Key.Code));
                        row.Cells["Haulier"].Value = truck.HaulierName;
                        row.Cells["References"].Value = string.Join(",", TsData.OutboundLoads.Where(t => t.TruckID == truck.TruckID).GroupBy(l => l.DeliveryReference).Select(l => l.Key));
                        row.Cells["ManifestNo"].Value = truck.TruckID;
                        row.Cells["Categories"].Value = string.Join("/ ", TsData.OutboundLoads.Where(t => t.TruckID == truck.TruckID).GroupBy(l => l.BaseCategory).Select(l => TsData.BaseCategories.Single(t => t.Value == l.Key).Name));
                        row.Cells["DepartBy"].Value = truck.DepartBy.HasValue ? truck.DepartBy.Value.ToString("yyyy-MM-dd HH:mm") : null;
                        row.Cells["ActualDepart"].Value = truck.DepartureTime.HasValue ? truck.DepartureTime.Value.ToString("HH:mm") : null;
                        row.Cells["DriverPhone"].Value = TsData.Drivers.Any(d => d.DriverName == truck.DriverName) ? TsData.Drivers.Where(d => d.DriverName == truck.DriverName).Single().Phone : null;
                        row.Cells["DriverName"].Value = truck.DriverName;
                        row.Cells["DriverDue"].Value = truck.DepartBy.HasValue ? truck.DepartBy.Value.AddMinutes(-45).ToString("yyyy-MM-dd HH:mm") : null;
                        row.Cells["Reg"].Value = truck.Registration;
                        row.Cells["Trailer"].Value = truck.TrailerRef;
                        row.Cells["TrailerType"].Value = truck.TrailerTypeRequirement;
                        row.Cells["BookingTime"].Value = TsData.OutboundLoads.Where(l => l.TruckID == truck.TruckID).Count() > 0 ? TsData.OutboundLoads.Where(l => l.TruckID == truck.TruckID).Min(l => l.DeliveryEta).ToString("yyyy-MM-dd HH:mm") : null;
                        row.Cells["ETAToDepot"].Value = truck.DepartureTime.HasValue ? (truck.DepartureTime.Value.Add(TsData.OutboundLoads.OrderBy(l => l.DeliveryEta).First().Consignee.TravelTime)).ToString("HH:mm") : null;
                        long[] loadids = TsData.OutboundLoads.Where(l => l.TruckID == truck.TruckID).Select(l => l.LoadID).ToArray();
                        row.Cells["Pallets"].Value = TsData.Orders.Where(o => loadids.Any(l => l == o.LoadID)).Sum(o => o.OvrReqStorage.HasValue ? o.OvrReqStorage : o.ReqStorage);
                        row.Cells["Notes"].Value = truck.Notes.Any(n => n.NoteHead == "Loads Out Notes") ? truck.Notes.First(n => n.NoteHead == "Loads Out Notes").NoteDetails : "";
                        row.Cells["Collections"].Value = string.Join("\n", TsData.InboundLoads.OrderBy(l=>l.CollectionTime).Where(l => l.TruckID == truck.TruckID).Select(l => l.CollectionTime.ToString("HH:mm") + " " + TsData.Customers.Single(c => c.Account_Ref == l.Account_Ref).Name + ", " + l.SiteName + (l.StockCategory.ToUpper() == "X" ? " (PTZ)" : "")));
                        row.Cells["ManifestNotes"].Value = string.Join("\n",truck.Notes.Where(n => n.NoteHead != "Loads Out Notes").Select(l=>l.NoteHead));
                        row.Cells["Loaded"].Value = truck.OutboundLoads.Any(l=>l.LoadedAt.HasValue);
                        row.Cells["ETAIntoCML"].Value = truck.ETAintoCML.HasValue? truck.ETAintoCML.Value.ToString("dd/MM/yy HH:mm"): "";
                        row.Cells["DriverArrived"].Value = truck.DriverArriveTime.HasValue? truck.DriverArriveTime.Value.ToString("dd/MM/yy HH:mm") :"";
                        row.Key = truck.TruckID.ToString();
                        row.AutoHeight();
                    this.Invoke(inv);
                i++;
            MethodInvoker inv2 = delegate
                        while (iGrid1.Rows.Cast<iGRow>().Any(r => !TrucksToDisplay.Any(t => t.TruckID.ToString() == r.Key)))
                            iGrid1.Rows.RemoveAt(iGrid1.Rows.Cast<iGRow>().First(r => !TrucksToDisplay.Any(t => t.TruckID.ToString() == r.Key)).Index);
            this.Invoke(inv2);
        private void dateTimeInput1_Click(object sender, EventArgs e)
        private void dateTimeInput1_ValueChanged(object sender, EventArgs e)
            UpdateTable((DateTime?)null);
        private void LoadsOut_Shown(object sender, EventArgs e)
            dateTimeInput1.Value = DateTime.Today;
            TsData.TruckLoadsUpdated += TsData_TruckLoadsUpdated;
        void TsData_TruckLoadsUpdated(object sender, EventArgs e)
                UpdateTable((DateTime)sender);
            this.Invoke(inv);
        private void iGAutoFilterManager1_FilterApplied(object sender, TenTec.Windows.iGridLib.Filtering.iGFilterAppliedEventArgs e)
            labelX1.Text = e.FilteredRowCount.ToString() + " Vehicles Visible";
        private void comboBoxEx1_SelectedIndexChanged(object sender, EventArgs e)
        private async void UpdateTable(DateTime? ChangeTime)
            if (!dateTimeInput1.IsEmpty)
                //iGAutoFilterManager1.SaveFilterToMemory("Current");
                if (!ChangeTime.HasValue)
                    //iGAutoFilterManager1.ClearFilter();
                    iGrid1.Rows.Clear();
                var v = (string)comboBoxEx1.Text;
                UpdateRunning isrunning = new UpdateRunning() { Screen = "LoadsOut", Process = "UpdateTable", Started = DateTime.Now };
                try
                    TsData.IsDataInUse.Add(isrunning);
                    await UpdateTable(dateTimeInput1.Value.Date, v, ChangeTime);
                    TsData.IsDataInUse.RemoveAll(i => i.Process == isrunning.Process & i.Screen == isrunning.Screen);
                catch
                    //iGAutoFilterManager1.RestoreFilterFromMemory("Current");
                iGAutoFilterManager1.ReapplyFilter();
                //labelX1.Text = iGAutoFilterManager1.FilteredRowCount.ToString() + " Vehicles Visible";
        private void LoadsOut_FormClosing(object sender, FormClosingEventArgs e)
            TsData.TruckLoadsUpdated -= TsData_TruckLoadsUpdated;
        private void iGrid1_RequestEdit(object sender, iGRequestEditEventArgs e)
            var r = iGrid1.Rows[e.RowIndex];
            switch (iGrid1.Cols[e.ColIndex].Key)
                case "DriverName":
                    break;
                case "Notes":
                    break;
                case "DriverArrived":
                    if (e.Text == "")
                        e.Text = DateTime.Now.ToString("dd/MM/yyyy HH:mm");
                    break;
                case "ETAIntoCML":
                    break;
                default :
                    e.DoDefault = false;
                    break;
        private void iGrid1_RequestDropDownControl(object sender, iGRequestDropDownControlEventArgs e)
                case "DriverName":
                    iGDropDownList list = new iGDropDownList();
                    while (true)
                        try
                            list.Items.Add(new iGDropDownListItem("", ""));
                            list.Items.AddRange(TsData.Drivers.Where(i => i.HaulierName == (string)r.Cells["Haulier"].Value).Select(i => new iGDropDownListItem(i.DriverName, i.DriverName)).ToArray());
                            break;
                        catch
                            Thread.Sleep(50);
                    e.Control = list;
                    break;
        private async void iGrid1_BeforeCommitEdit(object sender, iGBeforeCommitEditEventArgs e)
            var truck = TsData.TruckLoads.Single(i => i.TruckID == (long)r.Cells["ManifestNo"].Value);
                case "DriverName":
                    TsData.DbReturnStatus rtn;
                    if ((string)e.NewValue == "")
                        rtn = await truck.SetDriverName("");
                    else
                        rtn = await truck.SetDriverName((string)e.NewValue);
                    if (!rtn.Success)
                        MessageBox.Show("Failed To Write To Database, Please try again");
                    break;
                case "Notes":
                    await truck.AddNote("Loads Out Notes", e.NewText);
                    break;
                    DateTime AriveTime;
                    if (DateTime.TryParse(e.NewText, out AriveTime))
                        var rtn2 = await truck.SetDriverTime(AriveTime);
                        if (!rtn2.Success)
                    else
                        MessageBox.Show("Invalid DateTime Format, Please try again");
                    break;
                case "ETAIntoCML":
                    DateTime eta;
                    if (DateTime.TryParse(e.NewText, out eta))
                        var rtn2 = await truck.UpdateETAtoCML(eta.ToString());
                        if (!rtn2.Success)
                    else
                    break;
                default:
                    break;
2016-05-08T15:54:38Z
Can you prepare and send us a sample we can use to reproduce this issue?
And are you using the latest version of iGrid.NET (5.0.2)?
David.CML
2016-05-09T09:53:30Z
I did receive an email telling me about 5.0.2 but don't have a link to download the full version so am using 5.0.0 still.
I'm not sure that I could build a sample as the screen uses an in software cache of data from a SQL Database and this data is updating at a relatively high frequency.
I could possibly allow remote access for a short period to see the component in use.
2016-05-13T06:44:24Z
David, I have been thinking about your problem. I even do not know how to help you if I can't reproduce the problem on my dev pc.
The only idea is that you use an async task and LINQ operators to populate iGrid. Perhaps, these objects remain in memory as they are referenced from the iGrid cells, and they are not processed by the GC. But I am not sure whether this is a problem of iGrid. This can be the general .NET infrastructure or something like that.
David.CML
2016-05-13T06:49:27Z
Thanks for your advice, i was thinking along the same lines but can't work out how to make sure that the items are disposed of properly in this case do you have any advice.
