EntityDev
2016-05-30T03:40:00Z
Hello again,
Is it possible to set the RowHeader Selected Color? I don't see a property for it, was just wondering if there's an override available or something.
2016-05-31T06:37:16Z
See my answer to your recent question about the look of the iGrid header. iGrid uses the same principle when it draws its constituent parts: if possible, the items are drawn using the OS visual style. But as I already wrote, this can be turned off - see the RowHeader.UseXPStyles property. And read the Row Header Look and Behavior topic in the manual, it lists all related properties you can use to configure the look of row headers.
