For the moment I use the iGrid version 6.0.38.
To answer your question, yes, I would like to get the full number version that is in my case 6.0.38.
The reason is that my VB6 apps are centralized on a file server. Only ActiveX are registered on local pc.
So, exe files are not deployed on local PC.
From time to time I upgrade the EXE file on the server.
Because of that, I would like to know whether the current iGrid version running on the user pc is the proper one or not.
I am aware that this check can only be done with minor releases.
I hope I was clear...
