Kiran Angara
2017-09-15T01:58:09Z
How to add a row in between other rows using iGrid popup ?
Could you please give any idea or example.
1
2
<- Add Row
3
Thank You.
2017-09-15T11:36:50Z
Is it a question about adding custom items to the built-in iGrid context menus or the iGrid method to insert new rows in the middle of the grid (or both)?
You can define custom context menu items with the ContextMenuCustomItems property of iGrid. For example, the following code adds 3 custom menu items to the default cell context menu:
With iGrid1.ContextMenuCustomItems(igContextMenuCell)
   .Add "Custom Item 1"
   .Add "Custom Item 2", False
   .Add "Custom Item 3", , True
There is a topic titled 'Customizing Context Menus' in the help file that explain in details this technique.
As for inserting rows, you can do that with the AddRow method if you specify the row to insert before with the optional vRowBefore parameter.
