SintUser
2017-10-24T08:22:23Z
Is there a way to customize the icon in a checkbox?
I try to set an image list, but it seems they are not supported for cells of checkbox type.
What I need is to "replace" the default square with tick with a custom image (one for 'true', and one for 'false') but with the standard behaviour of a checkbox cell (single click to switch the value)
Is there a way to accomplish this?
2017-10-24T13:55:57Z
Yes, there is a way to redefine the drawing of checkboxes in iGrid cells. You should use the IiGControlPaint interface for that. We have a topic in the electronic documentation that explains how to use this interface:
Click to View Image224 View(s)
Another example of this interface usage can be found in the iGrid main demo.
SintUser
2017-10-25T06:17:57Z
Thank you very much.
I will take a look at this feature, and I will try to implement it
