SintUser
2017-10-26T14:15:32Z
Hi to all,
I have this header
Click to View Image98 View(s)
The red square are where the filter effectively works! Why the filter effective area is misaligned with the filter button if the single cell header is arranged on two rows?
Thank you!
2017-10-27T11:56:12Z
It seems, it is a bug in the iGrid control. Give us some time to check this under the debugger. We'll contact you immediately when the fix is ready. Most likely, in the beginning of next week.
