EQUINOXE
2020-09-01T17:12:38Z
How can I find part of a text in an Igrid column.
Click to View Image101 View(s)
y need this.
Click to View Image89 View(s)
2020-09-02T05:33:23Z
The source code of the sample from the second screenshot demonstrates how you can filter iGrid using its SearchAsType object.
First, you need to configure this object:
fGrid.SearchAsType.Mode = iGSearchAsTypeMode.Filter;
fGrid.SearchAsType.MatchRule = iGMatchRule.Contains;
fGrid.SearchAsType.SearchCol = fGrid.Cols[1];
Then, set the text to search in the event handler of the TextChanged event of your filter box:
fGrid.SearchAsType.SearchText = myText;
EQUINOXE
2020-09-02T13:14:09Z
IS PERFECT, THANK SO MUCH
2020-09-03T11:55:21Z
Use the 'Thank' element at the bottom of the post to say 'thank you' instead of writing text 😊
