SirBavol
2017-10-31T07:13:03Z
Using a licensed version of 6.5 igrid, not sure if the demo version is different then the Licensed version.
never played much with the demo version, but love the version i have, so many things to make my code to look and be so much better!
I have the list for the combo box loading ok, shows the list just like its suppose to...
CheckGrid.Combos.Clear
With CheckGrid
With .Combos.Add("FirstRow")
Do Until tbl_Chk_Account_oRS.EOF
.AddItem tbl_Chk_Account_oRS("cDept_name"), tbl_Chk_Account_oRS("lAcc_id")
tbl_Chk_Account_oRS.MoveNext
Loop
.CellType(1, 1) = igCellCombo
.CellCtrlKey(1, 1) = "FirstRow"
and when i click on one of the items it shows in the box and sets the .cellvalue(1, 1) correctly
BUT what i can not figure out how to do...is if i set the .cellvalue(1, 1) using code
I would like the box to auto show the text in the box that matchs the value I set.
Like vb comboboxes, if you set the listindex in the code, the combobox show the right text that matches
the listindex you gave it in the vb code.
EX: when i click on the combo box and say click Grocery, it sets the .cellvalue to 2
what i want to do is set the .cellvalue to 2 and when the list loads, it shows Grocery, not blank.
its is setting the .cellvalue of the "lAcc_id" like i want it to. So Grocery's lacc_id is 2. SO when I set the
.cellvalue from the code, I would like it to read the lAcc_id and show the Text matching that.
Any help would be awesome. Thanks in advance.
2017-10-31T07:47:35Z
iGrid must display the corresponding combo list item text when you change the cell value. Can you send us a sample that demonstrates this problem?
SirBavol
2017-10-31T08:11:02Z
I have images, but not as URLs
Let me try and give you the code, that might help...
loading the grid...
With CheckGrid
.BeginUpdate
.Font.Size = 12
.Gridlines = igGridLinesBoth
' .GridlineColor = RGB(255, 192, 255)
.ColCount = 0
.RowCount = 0
.AddCol(sHeader:="ACCOUNT", lWidth:=315, eheaderalignh:=igAlignHCenter).eAlignH = igAlignHLeft
.AddCol(sHeader:="AMOUNT", lWidth:=160, eheaderalignh:=igAlignHCenter).eAlignH = igAlignHRight
.AddCol(sHeader:="INVOICE NUMBER", lWidth:=315, eheaderalignh:=igAlignHCenter).eAlignH = igAlignHCenter
.Header.Visible = True
.Header.Buttons = False
.Header.Font.Bold = True
.DefaultRowHeight = .GetOptimalCellHeight()
.AddRow
.CellFmtString(.RowCount, 2) = "#,##0.00"
.AddRow
.AddRow
.AddRow
.AddRow
.AddRow
For I = 1 To 6
.CellValue(I, 1) = "2"
.CellValue(I, 2) = "0"
.BackColorEvenRows = RGB(203, 255, 203)
.EndUpdate
then i load the combo boxs
strSQL = "SELECT * "
strSQL = strSQL & "FROM tblAccountTypes "
strSQL = strSQL & "ORDER by cDept_name ASC"
Set tbl_Chk_Account_oRS = New Recordset
tbl_Chk_Account_oRS.Open strSQL, goConnCB, _
adOpenForwardOnly, adLockReadOnly
With CheckGrid
Loop
.CellValue(1, 1) = "2"
tbl_Chk_Account_oRS.MoveFirst
With CheckGrid
With .Combos.Add("SecondRow")
Loop
.CellType(2, 1) = igCellCombo
.CellCtrlKey(2, 1) = "SecondRow"
With CheckGrid
With .Combos.Add("ThirdRow")
Loop
.CellType(3, 1) = igCellCombo
.CellCtrlKey(3, 1) = "ThirdRow"
With CheckGrid
With .Combos.Add("ForthRow")
Loop
.CellType(4, 1) = igCellCombo
.CellCtrlKey(4, 1) = "ForthRow"
With CheckGrid
With .Combos.Add("FifthRow")
Loop
.CellType(5, 1) = igCellCombo
.CellCtrlKey(5, 1) = "FifthRow"
With CheckGrid
With .Combos.Add("SixthRow")
Loop
.CellType(6, 1) = igCellCombo
.CellCtrlKey(6, 1) = "SixthRow"
tbl_Chk_Account_oRS.Close
CheckGrid.ShowControlsInAllCells = True
when I load the program, it makes all the combos and lets me using them right. and if i click on one and click on an item in the list
it changes the .cellvalue to the right number.
But as you can see by the ones that i have underlined, i am trying to get it to show the Second Item in the list when it loads...in this case
the word "Grocery"
it sets the .cellvalue to 2 changing the -1 setting, but still shows blank in the box. like its still set to -1
and if i click on the box, and click Grocery, it then shows up and sets the .cellvalue to 2 again. Im at a loss...
2017-10-31T15:19:25Z
I guess the problem is in the following code:
   Loop
When you write an expression like tbl_Chk_Account_oRS("lAcc_id"), in fact you reference the whole ADODB.Field object. Yes, its default property is Value returning the value of the field, but in this case you reference the ADODB.Field object stored instead of the value. To fix the problem, try to use the following modification of the AddItem call:
.AddItem tbl_Chk_Account_oRS("cDept_name").Value, tbl_Chk_Account_oRS("lAcc_id").Value
Two ideas how to simplify your code.
First, the iGrid ComboObject also provides you with the FillFromRS method starting with the v6.5. Having this, the above code block can be replaced with the following call:
.Combos.Add("FirstRow").FillFromRS tbl_Chk_Account_oRS, "cDept_name", "lAcc_id"
Second, the following code block
.AddRow
.AddRow
.AddRow
.AddRow
.AddRow
.AddRow
can be simplified using the default column cell:
.ColDefaultCell(2).sFmtString = "#,##0.00"
.RowCount = 6
This forum contains a step-by-step instruction how to upload images to your posts:
Upload images to this forum
SirBavol
2017-10-31T16:30:11Z
Thank you for the code suggestions, made the code so much smaller!
ok now it looks like this
With CheckGrid
.Combos.Add("SecondRow").FillFromRS tbl_Chk_Account_oRS, "cDept_name", "lAcc_id"
.Combos.Add("ThirdRow").FillFromRS tbl_Chk_Account_oRS, "cDept_name", "lAcc_id"
.Combos.Add("ForthRow").FillFromRS tbl_Chk_Account_oRS, "cDept_name", "lAcc_id"
.Combos.Add("FifthRow").FillFromRS tbl_Chk_Account_oRS, "cDept_name", "lAcc_id"
.Combos.Add("SixthRow").FillFromRS tbl_Chk_Account_oRS, "cDept_name", "lAcc_id"
as you can see i set .cellvalue(1, 1) = 2 for the FirstRow .combos.add
on this image it shows them all loaded, perfect.
Click to View Image205 View(s)
This image shows them all in there and if i click on one of them it puts it in the box to see
Click to View Image201 View(s)
like this
Click to View Image200 View(s)
this is what it looks like when i use the .cellvalue set to 2 in the first combobox, I want it to show the listing like it does when i click on it.
I was hoping to make it look like this when it loads it from the code so it shows up like this as the default
with out them having to have clicked on it.
Thank you for taking the time to work on this. JAnd the quick responses, this is an awesome learning experience for me
2017-10-31T16:51:58Z
Is there a difference between
and
.CellValue(1, 1) = 2
Looking at the filed names used as the combo item values, I think you use numeric IDs. Thus, you need to assign numeric values to CellValue to make it work.
SirBavol
2017-10-31T17:01:46Z
Yes there is, with out the "" it worked perfect!!!!!!!!!!!!!
THANK YOU SO MUCH!
Now if you could make it so the mouse scroll wheel works in the combobox you will be my HERO!!!!!
2017-11-01T12:54:15Z
iGrid''s drop-down lists are based on the native Windows combo box functionality that supports mouse wheel scrolling out-of-the-box. Just in case, I have just tested combo box cells from the latest release of iGrid (6.5.80) with 3 mices I found in the Office from different vendors (Logitech, Trust, Rapoo). All they can be used to scroll the combo list contents using the mouse wheel.
From my experience I can tell that not all mices send the proper Windows messages to scroll the contents. Perhaps, this is the reason why your mouse can't be used for that. Try to use another mouse and tell us whether its wheel scrolls iGrid drop-down lists.
If possible, please, let's discuss this in another new thread with the subject corresponding to the problem. The subject of this thread is not relevant to the problem you touched.
