The demo installs the demo version of the OCX, so be ready to see nag screens :)
To avoid this, overwrite the demo OCX with the full one.
Hi, I am getting a compile error message when opening a file with the iGrid control. It says it is missing the project or library.
I thought I was good to go on this, but I guess not. if you recall, once I had the control configured and working code to populate it on my office PC, I ran into trouble running it on the conf room computer, but after installing the iGrid Demo on that conf room PC, it was working fine, but the file I was using was a dummy file for testing the iGrid control.
I am now trying to test it with the "Real" file. On my office PC, I can get it going just fine (although I had to manually enable the 10Tec controls via the toolbox/Add Controls dialog box and also manually enable the DynamicContentEvents = igDCEventsRowDynamicFormatting via the immediate window). Otherwise, everything was good.
I though maybe it wasn't registered properly, but the original "dummy file" from before still works just fine, even on the conf room computer. I literally dragged the form and the associated code from the "Dummy" file to the "real" file, so I don't see what the problem is. I have made sure to enable the two 10Tec controls (iGrid and ImageList), but I don't see what the problem is.
Any ideas? by the way, I am running 64 Bit Windows 10 on the Conf Rm Computer.
