That's a really strange issue, and we hear about this problem for the first time. A couple of questions which can help us to investigate the problem:
1) Does this happen only when you add iGrid to your forms?
2) Does this happen with any project, or only with one specific?
3) Give us a screenshot of the problem, please.
And one more note regarding Vista/Windows 7 - check that also please.
In Windows Vista/7, you may need to do one more step after you downloaded the full version of the control's DLLs. Due to the improved security system in these OS’s, you will need to unblock the iGrid.NET constituent files as they came from the unsecure Internet zone. To do that, open the properties of each DLL and click the Unblock button on the General tab in the File Properties dialog. You may need to do that for the second versions of the files created by Windows automatically (such as TenTec.Windows.iGridLib.iGrid 2.dll, TenTec.Windows.iGridLib.iGrid 2.xml, etc).
