frdata
2017-11-26T17:54:21Z
How to avoid last column from partially blocked. This happens very often. iGrid version 6.00.003
Click to View Image214 View(s)
2017-11-27T14:58:15Z
When you set some first columns as frozen in the current version of iGrid ActiveX, iGrid switches to scrolling by columns in the horizontal direction (aka integral scrolling). However, as I see, this does not work right for some column sets.
Can you prepare and send us a simple sample we can use to reproduce your problem and fix it?
frdata
2017-11-28T00:56:14Z
Please have a look at the following sample (attached as zip file) :
https://drive.google.com...XvqCmE4/view?usp=sharing
2017-11-28T16:10:05Z
Thank you for your sample - it really helped to understand what happens inside iGrid if we populate it with your column set. I confirm that the problem is on our side and it is related to scrollable columns with zero width.
I have already implemented a bug fix for this problem and sent you the link to the iGrid OCX with this bug fixed in an email. Test the new version and let us know whether it works properly now.
frdata
2017-11-29T17:20:24Z
Your latest version 6.50.82 solved all the issues that I had about partially blocked columns. I hope that more and more developers will turn to iGrid for their ultimate grid solution.
Thank you sir
