Hello, i have an issue with readability on the grid
I'm using font "Segoe UI" point size 8, with some text the characters seem to be placed too close to each other, using less space than other application that also use the same font and size.
This causes the text to be hard to read in some cases.
Attached is an image of the problem. My Grid.Net results are above, and the exact same text is displayed below as Outlook draws it. You can see that the Grid.net control uses less space to print the same text
Is there a way to change how much space is used between characters when drawing the text on the screen?
Click to View Image257 View(s)
Edited by moderator
2017-12-06T15:22:19Z
Reason: Igor/10Tec: changed post status to 'question'
