Bodmoor
2018-01-05T08:50:33Z
I've made a combobox that displays a text value and an icon. I can choose another value, and the displayed value in the cell shows the icon just fine. In the drow down menu on the other hand, no icons are shown. I cannot figure out how to show the icons in the drop down menu as well, how can I achieve this?
example dropdown
Bodmoor
2018-01-05T08:55:49Z
And I have figured it out; the image list needs to be set separately:
comboObject.SetImageList([your list])
2018-01-05T16:46:50Z
Yes, you are right. The image lists used in the main grid and its combo lists may differ as you may want to use images of different sizes in cells and combo lists. To do that, iGrid provides you with the ability to attach a personal image list to every combo list. But in the simplest case, you simply use the same image list everywhere.
