Puffeltje
2012-06-02T20:48:05Z
My last version of iGrid is V3.0.0
Recently i formatted my harddisk. The full version V3.0.0 of igrid and the printmanager i have in my backup. I tried to reinstall igrid with the demo of igrid V3.0.42.0. The installation of the demo went good; no errors. When i start the demo and look at the version of igrid it says V3.0.42.0. When i than replace the demofiles with the full-version-files the demoprogram still say the version is V3.0.42.0
VB2010 also gives problems: in my old projects i see the grids but i can't select them. After i rebuild the project the grids are still there but all the columns are gone. BTW, the grids are showed in the component tray.
Is it possible to install V3.0.0-full with demo V3.0.42.0 ? If not: where can i find the demo V3.0.0 ?
Puffeltje
2012-06-03T14:22:42Z
Problem solved:
on an old harddisk i found the demo V3.0.0.0
After disinstalled V3.0.42.0 i installed the demo V3.0.0.0. After that i copied my full-version V3.0.0.0 over the demo-files. All the problems are gone: no more grids in the component tray, all the grids are selectable in the project, after rebuilding the project the columns in the grids aren't gone.
I think it is wise to add the demo V3.0.0.0 to the downloadsection at the site because the demo V3.0.42.0 isn't compatible with the full version V3.0.0.0
2012-06-06T09:33:37Z
Yes, you're totally right - we should provide the users with the ability to download the demo of the release version of iGrid.NET 3.0 (build 3.0.0) for such cases like this one. We found it in our archives and uploaded to the webserver. The direct link to it can be found on the Previous Versions page in the Download Section.
