You can easily use hTooltip together with iGrid ActiveX to display an individual tooltip for every cell. Here is the basic code snippet for the form's module:
Dim hTT As New CTooltip
Private Sub Form_Load()
Dim grd As iGrid
Set grd = iGrid0.Object
With iGrid0
.ColCount = 3
.RowCount = 5
With hTT
.Title = "hTooltip"
.Icon = httIconInfo
.Text = "Hello from hTooltip!"
.CreateForVBCtrl grd
Private Sub iGrid0_MouseEnter(ByVal lRow As Long, ByVal lCol As Long)
hTT.Text = "Row: " & lRow & ", Col: " & lCol
If the tooltip has appeared, and you move the pointer from one cell to another, the tooltip text is changed accordingly like on the attached screenshot.
Sure, there can be more complex scenarios. For instance, you may need to hide the tooltip when it is on an empty space (outside of any cell). Such iGrid events like MouseLeave/MouseMove which provide you with the row and column indices and CTooltip's methods (Hide, Show, ...) will help you in that.
