SintUser
2018-06-29T07:07:01Z
Hi to all,
I have a column of numbers, but when I sort the column clicking on header. The sorting is wrong. The negative numbers are sort by absolute value.
Example:
If I have 2, -2, 4, 0, 1 the sorting is 0, 1, -2, 2, 4. Why?
Thank you
2018-06-29T17:35:16Z
Strange, they should be sorted properly - I have just checked that just in case.
Can you send us a sample project that demonstrates your problem?
