SintUser
2018-08-29T14:18:36Z
Hi to all,
Is there a way to know the rows displayed?
For example I have a table with 100 rows with "visible" property = True, but the window is small and the igrid shows only 10 rows. Is it possible to know what these rows are?
Thank you
2018-08-30T06:39:13Z
The GetStartEndCells method of iGrid allows you to retrieve the column/row indices of the first and last cells visible in the viewport. The row index of the first visible cell and the row index of the last visible cell are the values you need.
