Horst
  • Horst
2013-12-04T09:07:12Z
I am starting today to test iGrid & iGAutoFilterManager.
In our architecture with split gui and business: For the gui layer it is forbidden to access local files.
The methods of iGAutoFilterManager (SaveFilterToFile(…), RestoreFilterFromFile(…)) access to local files. I would get the configuration setting from the iGAutoFilterManager as a string. This string I will give to the business layer - and backwards.
Is there a possibility to get and set the filter configuration with a string?
thanks Horst
2013-12-05T08:35:07Z
The iGColAutoFilter object returned by the AutoFilterManager's ColAutoFilter method has the FilterAsBase64String property. Use it to retrieve/set the current filter for an iGrid column as string.
Pay also attention to the SaveFilterToMemory/RestoreFilterFromMemory methods which allow you to save/restore the grid filter in memory without accessing the file system.
