yagocor
2022-05-18T05:44:50Z
hello,
for manual insert, is possible append child rows in random order?
in your example is possible only in sequential mode:
- root
--child
instead i want use your grid in this mode:
- root_1
- root_2
- root_N
and after add child rows
--child_of_root_2
--child_of_root_1
--child_of_root_3
thanks in advance
best regards
2022-05-19T16:34:50Z
Yes, sure. You can insert root and child rows in any order. The only obvious recommendation is that a parent must be inserted before you add its children.
yagocor
2022-05-19T18:01:52Z
hello Igor,
thank you so much for your reply
but your reply not resolve my problem because i should always bound to add first the parent
my situation is this: first i load all the parents and only after i want to hang up the children (example: lazy load of child after click on the parent...just for speedup the execution)
best regards
2022-05-20T15:38:06Z
Perhaps, we do not understand each other. Yes, what you described in your last post is possible.
If you have problems with implementing this functionality, you can send us a sample for further consideration. One code sample is worth a thousand words 🙂
yagocor
2022-05-20T18:16:13Z
from your iGridTreeHelperMethods_VB example:
original code:
iGrid1.AddRootNode("Root 1", "1")
iGrid1.AddChildNode("1", "Child 1.1")
iGrid1.AddChildNode("1", "Child 1.2", "1.2")
iGrid1.AddChildNode("1", "Child 1.3", "1.3")
iGrid1.AddChildNode("1.3", "Child 1.3.1")
iGrid1.AddChildNode("1.3", "Child 1.3.2")
Dim myRowRoot2 As iGRow = iGrid1.AddRootNode("Root 2") ' AddRootNode() returns the created iGRow object,
iGrid1.AddChildNode(myRowRoot2, "Child 2.1") ' which can be used later In AddChildNode() instead of parent string key
iGrid1.AddChildNode(myRowRoot2.Index, "Child 2.2") ' or we can even use numeric row index
iGrid1.AddRootNode("Root 3")
my test code:
... run code...and...
the child "2.1 and 2.2" are added to "root 3" instead of "root 2"
regards
2022-05-23T16:24:41Z
Now all is clear - the method names misled you. The Add* methods are used when rows are added to the END of iGrid. They just wrap some row-level-related functionality implying that rows are added to the end. What you need is the equivalent Insert* methods:
iGrid1.InsertChildNode(myRowRoot2, "Child 2.1")
iGrid1.InsertChildNode(myRowRoot2.Index, "Child 2.2")
