KGunder
2014-04-23T16:04:40Z
using the incremental search in iGrid it would be nice to jump to the next occurence matching the already entered text (e.g. pressing the enter key)
( My Grid has .Editable = False so hitting enter will currently do nothing )
Best regards
Klaus
2014-04-25T15:43:26Z
Doing this by ENTER is not a good idea if the grid is editable. Instead, it should be a special key combination like ALT+DOWN ARROW. We do that in our iGrid for .NET - see the attached screenshot.
I will think about your suggestion, it's really useful. Perhaps, in later releases.
2014-08-21T14:54:42Z
This suggestion was implemented in iGrid 5.0 build 0094 we've published today. Here is the corresponding excerpt from the What's New document:
Цитата:
Two new keyboard combinations can be used during incremental search: ALT + DOWN ARROW finds the next match below the current cell, ALT + UP ARROW finds the previous match above the current cell. If there is no next match when pressing these keys, the current cell remains unchanged.
