Hi, Igor
1) We can select an area of cells with the mouse.
If the first cell of the zone to be selected is the active cell, then, when you click on it to start the selection, it goes into edit mode and selection with the mouse becomes impossible.
Could the "SingleClickEdit" property (True or False) also have the "DoubleClick" to put a cell in Edit mode which would avoid this problem?
Maybe there is a way to do this but I haven't found it.
2) And a small question : Can we write numbers (or others) in the left column (RowHeader)
Excuse my english
Thank You
Stephane
France
Edited by moderator
2022-10-06T08:30:38Z
Reason: Igor/10Tec added status [IMPLEMENTED]
