Hi I am a new user of IGrid Active X control together with MS Access
I did find your example database that is bundled together with
the demo application and help files very useful to get a head start
of using Igrid and MS Access together.
But after have gone through your example database i wonder if u have any more
Access example databases with more sophisticated use of IGrid.
So to replace a continuous form or a datasheet in Ms access we often
need to replace some of the inbuilt functionality that exist in Access.
Then to have a test database with more examples would be a great help to get kick started :-)
Typical question :1. In my case i work up against MS SQL server and not the Jet database how insert in a SQL table with a Primary Key with identity increment.
2. The use of Combos linked to a relational table where we insert the Key ID but show the Text field from the table
3. Hide columns in the Grid but have the values available.
Thanks
PSH
Edited by moderator
2014-03-14T13:34:11Z
Reason: Igor/10Tec made the subject more detailed
