Strange... I can't reproduce this. Can you send me a simple sample to demonstrate the problem? You can use a command button instead of your custom menu for simplicity.
It becomes even stranger...
After several tests I have run into the safe conclusion that when the "Groupby sub" is called from a button, everything works ok.
If exactly the same sub is called from Access popup menu or even iGrids custom menus, there is no trigger to the CustomGroupValue.
(As I mentioned before, from the standard menus everything works ok)
Here is an example:
db50.zip
(15kb) downloaded 229 time(s).(original external DropBox link:
MDB Test File )
Please open “Form1”.
Group By, from header standard menu, triggers the event.
Group By, from command button, triggers the event.
Group By, from cells custom created menu, does not trigger the event.
P.S. I’m in a trial period and I am using the demo version.
Edited by moderator
2016-11-10T11:39:09Z
Reason: Igor/10Tec: uploaded MDB sample to the internal forum file store
