I try to use the keyboard shortcut CTRL+C to copy the content of my grid. Unfortunately it does not work.
However it works well with the built-in context menu.
I've read the iGrid documentation about "Copy/paste Functionality" and it seems to be possible to use keyboard shortcuts...
iGrid ActiveX 6.0 documentation:
"The copy/paste commands are: Cut, Copy, Copy with Headers, Paste. You see them in this order in the built-in context menu. The keyboard shortcuts for these commands are CTRL+X, CTRL+C, CTRL+SHIFT+C, and CTRL+V respectively."
Any idea ?
Thank you.
