Manuel Langeheinecke
2018-02-25T14:35:48Z
I use this function to update/fill the grid:
With iGrid0
.BorderType = igBorderThinFlat
.Clear True
.BeginUpdate
.AddCol sHeader:="ID", sKey:="ID", bVisible:=False
.AddCol sHeader:="Re-Datum", sKey:="Re-Datum", lWidth:=70
.AddCol sHeader:="Re-Nummer", sKey:="Re-Nummer", lWidth:=80
With .AddCol(sHeader:="Preis", sKey:="BETRAG", lWidth:=75)
.eAlignH = igAlignHRight
.sFmtString = "#,##0.00 €" '"#.##,## €"
.AddCol sHeader:="Firma", sKey:="Lieferant", lWidth:=180
.AddCol sHeader:="Verwendungszweck", sKey:="Verwendungszweck", lWidth:=264
.AddCol sHeader:="HH-ST", sKey:="HH-ST", lWidth:=88
.AddCol sHeader:="Fach", sKey:="Fach", lWidth:=31
Dim rs As DAO.Recordset
Set rs = CurrentDb.OpenRecordset(strSQL, , dbOpenSnapshot)
.FillFromRS rs
.EndUpdate
Everything works fine, i see the rows in the grid.
After updating the strSQL i see the another result. Fine!
Now, when it comes to the point that the SQL-Query results to 0 rows, i see 0 Rows in the Grid. Fine!
Here starts the problem: At this point no rows will ever be displayed after updating the SQL-Query again, even if the Query results 1000+ Rows.
Can anybody explain, what i', doing wrong?
2018-02-26T07:52:56Z
We need a sample to reproduce the problem. Can you implement it and publish it here or send to our support email address?
And what is your development environment? Judging by the control name (iGrid0) it's MS Access. If so, the question should be moved to the related MS Access subsection of this forum.
