I am new to iGrid... so you'll need to go slowwwwwly!!!
I have 3 questions:
1) As you may see in Fig 1 I have two "Header Columns" but I cannot get the second header to "freeze" (similar to first 3 columns). Can I do this? ie stop the Month going up and being hidden.
2) Is there something that I can do about the repeating numbers in the second column header? eg I would like to just print "July" once across top.
3) Similar to the 1st question -- is there any way that I could get the "sort option" to work WITHOUT the first rows?
4) Is there anything that I could do to speed up the code : eg Virtual
Click to View Image57 View(s)
I have copied the code (except for the SQL) in the following snippet:
Private Sub Form_Load()
Dim rs As ADODB.Recordset
Dim i As Long
Dim j As Variant
Dim Start As Long
' This allows us to use IntelliSense below
Dim grd As iGrid
Set grd = iGrid1.Object
grd.FrozenCols = 3
grd.FrozenColsEdgeColor = vbRed
j = 0
' Create the column structure - we'll use a subset of all the fields in the table.
' The keys of the columns are field names.
With grd
.DrawRowText = True
.AddCol sKey:="SerNo", sHeader:="Project No."
.AddCol(sKey:="nrcan projectstartdate", sHeader:="Start Date", lWidth:=190).sFmtString = "dddd, mmm d yyyy"
.AddCol(sKey:="nrcan projectenddate", sHeader:="End Date", lWidth:=190).sFmtString = "dddd, mmm d yyyy"
For i = 4 To 368
.AddCol sKey:=i - 3, sHeader:=DateAdd("d", CStr(i - 4), m1stDate)
.AddRow 'vRowParent:="SerNo"
For i = 4 To 368
.CellValue(1, i) = Month(DateAdd("d", CStr(i - 4), m1stDate))
.RowHeight(1) = 40
' Here we populate iGrid using our column structure
Set rs = CurrentProject.Connection.Execute("SELECT * FROM xtblPCSPCaseFile") ' or even simply use "Customers" instead of the SQL query
grd.FillFromRS rs, EMode:=igFillRSAddToExistingRows, vRowKeyField:="SerNo"
For j = 1 To grd.RowCount - 1
Start = modScreen.Get1stDateDiff(CDate(grd.CellValue(j + 1, 2))) + 4
grd.CellValue(j + 1, Start) = "S"
grd.CellBackColor(j + 1, Start) = RGB(255, 0, 0)
' Automatically enlarge columns to show cell contents without clipping
grd.AutoWidthCols
Marty H.
President
mhHawk Computing Corp.
