Emil
  • Emil
2016-10-31T02:13:47Z
I inserted in an iGrid a Check Boxes column,
within iGrid initialization I declared
the AggrFuncsObject
the Group-Objekt
.GroupObject.AddItem "check", igSortDesc, igSortByCheckState
.PrefixGroupValues = False
In the
AfterAutoGroupRowCreated Event
I added
iGrid1.CellValue(lRow, iGrid1.RowTextCol) =…
to Sum (aggregation) some other cells.
Up to know all is working.
If I know change „Chekbox-column“ details and use
Group in the iGrid0_AfterCellCheckChange event
Group will start and group iGrid new but the summation function does not recalculate the sums new.
How can I recalculate the iGrid after check cells in the Check Boxes column?
Thank you for support
Emil
2016-10-31T07:29:02Z
If I understand you right, you need to calculate the sum values for rows with checked and unchecked cells separately and display these total values in the group rows. I have just tried to recreate this functionality in VB6. Here is the source code of my test form's module:
Option Explicit
Private Sub Form_Load()
   With iGrid1
      .BeginUpdate
      .ColCount = 3
      .ColKey(2) = "check"
      .ColDefaultCell("check").bCheckVisible = True
      .RowCount = 5
      .CellValue(1, 1) = "a"
      .CellCheckState(1, 2) = igCheckStateChecked
      .CellCheckState(3, 2) = igCheckStateChecked
      .CellValue(1, 3) = 11
      .CellValue(2, 3) = 22
      .CellValue(3, 3) = 33
      .CellValue(4, 3) = 44
      .CellValue(5, 3) = 55
      .AggrFuncs.Clear
      .AggrFuncs.AddItem 3, igAggrFuncSum
      .Group
      .EndUpdate
Private Sub iGrid1_AfterAutoGroupRowCreated(ByVal lRow As Long, ByVal lItemCount As Long, ByVal vAggrFuncValues As Variant)
   iGrid1.CellValue(lRow, iGrid1.RowTextCol) = vAggrFuncValues(1)
Private Sub iGrid1_AfterCellCheckChange(ByVal lRow As Long, ByVal lCol As Long, ByVal eOldCheckState As iGrid600_10Tec.ECellCheckState)
   iGrid1.Group
This works. When I click a check box cell, the grid is regrouped according to the new set of checked and unchecked cells and the sum values are also recalculated correctly:
Click to View Image134 View(s)
Click to View Image142 View(s)
Can you send us a sample that demonstrates your problem?
Emil
  • Emil
2016-10-31T08:59:04Z
sorry Igor for my bad english...
this part of the code works
it works not if I change the value of the Check box and regroup
here my Code
  10TecCode1.txt (4kb) downloaded 128 time(s).
Click to View Image152 View(s)
Click to View Image149 View(s)
there is only the initial Sum in the last row
I expect to see the Sum of the columns 5 and 6 in the checked and unchecked group
Thanks for support Igor
Emil
2016-11-01T07:48:45Z
I need a sample I can launch on my pc to see the problem. Can you prepare one?
Emil
  • Emil
2016-11-03T06:22:27Z
  igridtest.zip (62kb) downloaded 137 time(s).
Gi Igor,
i attachmend a full functional example
thanks
2016-11-03T10:20:52Z
Emil, I recalled that this problem with the AfterAutoGroupRowCreated event in MS Access had been already discussed on our forum:
AfterAutoGroupRowCreated-event not triggering
It's a glitch of MS Access: the AfterAutoGroupRowCreated event is not fired if you do something related to grouping in another iGrid event. Nobody found a workaround yet, and the only solution is to recalculate the total values from another event handler/control. For instance, you can use a dedicated button for that.
One more hint regarding your code. You need to remove rows with level 0 from your grid before regrouping it. Otherwise you will get unneeded rows like the last one on your second screenshot.
Emil
  • Emil
2016-11-06T09:38:10Z
Igor,
can you provide a example to me regarding the timer event?
"To avoid this, launch a timer in AfterCommitEdit and perform your reloading/updating in the timer's event. In this case these actions will be done OUTSIDE of AfterCommitEdit, when it has completely finished."
What timer ist this - igrid timer? I didn,t found a igrid timer:-(
Thank you
Emil
2016-11-07T10:09:03Z
It is amazing, but it seems our Universe is really synchronistic: another developer has sent us a workaround for this problem a couple of days ago! I've checked it, and it really works, and it can be used in your database too.
The solution is enough simple. You need to define a variable of the iGrid type equipped with WithEvents on the form module level, assign the problem iGrid object to it during the form initialization and then write event handlers for this new object variable. A step-by-step instruction is the following.
First, declare this form variable:
Private WithEvents xGrid As iGrid
Second, add the following statement at the top of Form_Load:
Set xGrid = iGrid0.Object
And finally, replace event declarations for your form control like
Private Sub iGrid0_AfterAutoGroupRowCreated(...)
with this one:
Private Sub xGrid_AfterAutoGroupRowCreated(...)
That's all. Try that, and tell us whether it works. I did this on my pc in your copy of the database, and it worked.
P.S. This solution was published as a KB article on our forum here:
iGrid events are not always raised in MS Access
2016-11-10T11:24:36Z
Emil , as you asked, here is my implementation of the requested functionality:
  igridtest4.zip (35kb) downloaded 131 time(s).
I removed some code from the original database to make my idea clearer (for instance, the ColHeaderDblClick event handler with the non-existing igrid0_Statistik call). I also added the 'WithEvents' workaround and rewrote the previous code so now it uses xGrid everywhere.
The most interesting part of my implementation is a timer used to regroup iGrid outside of the AfterCellCheckChange event. iGrid contains a special service CTimer class, which is a non-visual timer implementation. Anyone can use it in VBA code, and I did this in my solution. I define this timer var on the form-module level:
Private WithEvents xTimer As CTimer
, and then use it in code like this:
' Start the timer
xTimer.Interval = 1
' Timer event to perform our regrouping actions
Private Sub xTimer_ThatTime()
A brief 'documentation' for the CTimer object. Its Interval property is used to specify the timer period and launches the timer automatically if you assign a non-zero value to it. The ThatTimer event is fired to notify you that the specified interval elapsed. That's all. Enjoy!
