I have many sources (in the example 2: Test1 and Test2)
Clicking on the first table I see the data in the second table correctly. All data (of both sources are in the table at start)
Click to View Image75 View(s)
Click to View Image71 View(s)
If I click on filter I see Test1 and Test2 but I want see only Test1 if selected is Test1 (or Test2 if selected is Test2)...
And if I click on Ok i see all data...
I would like to be able to put only some values in the filter window and If I reset all filter filters return to the initial situation.
Is it a bit clearer now? how could I do?
Thank you
